Where to get some round tube bent?
发表于 2021-9-1 00:46:57 | 显示全部楼层 |阅读模式
I'm gonna make a frame for my swamp cooler. I need 4 90 degee elbows made from 1" round tube. Where can I get this done? Steel store wants 25$ to do it. Seems high. RyanLincoln PowerMig 180cVictor O/ABandaids and aspirinI don't know what I don't know!?
Reply:Well you could buy 3/4" 90 degree weld on pipe elbows and use them.  the 3/4" pipe should match up pretty close with your 1" tube on the outside diameter.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:$25 for four kink-free bends sounds just fine to me.
Reply:Originally Posted by Hammack_WeldingWell you could buy 3/4" 90 degree weld on pipe elbows and use them.  the 3/4" pipe should match up pretty close with your 1" tube on the outside diameter.
Reply:Just go to any muffler shop. the bends are compression type bends leaving a slight indentation on the inside of the bend but for a swamp cooler this may be acceptable for you.Also if it is a swamp cooler why not just use conduit? Then you can get a conduit bender at the hardware store and do as many bends as you need.If you really want a smooth bend ,that is called a mandrel type bender.Welding stores (NOT BIG BOX STORES) sells welding elbows.AWS certified welding inspectorAWS certified welder
Reply:25/4 bends seem alright.  25 each and you are probably making a payment on his machine.
Reply:A muffler shop will bend 1" tubing?
Reply:Mitre cuts are freeEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-21 08:56 , Processed in 0.069203 second(s), 18 queries .
