A couple of my projects
发表于 2021-9-1 00:21:30 | 显示全部楼层 |阅读模式
Here are a couple of my projects that I have done. Attached Images
Reply:it seem you will be saving a lot on bandsaw... and toys... that is good weldin I see...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:im liking that english wheel(if i remeber, thats what its called, no?). nice builds!
Reply:I can't see a single weld on that scroll saw.
Reply:It is an english wheel and there are no welds on the scroll saw but its a metal working project. More than one way to join two peices of metal to make something. Welding and machining go hand in hand. Ane the scroll saw was way harder of the two to build.
Reply:Originally Posted by 69 chevyI can't see a single weld on that scroll saw.
Reply:Originally Posted by westlawn5554xI wuz refering to the blue stand... you need only see the whole pic beside the bright SS ball...
Reply:so you have a stove for the hardening process...?Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:I have access to one if I need it. I built this a project while taking machine shop class about 2 years ago. I still have access to all the equipment over there. I helped teach a little after I graduated from the program. I did that on my off days from the ambulance service. Working 24 on and 48 off I have plenty of time for other ventures. Thats why I am trying to get my truck and shop set up for a small welding and machine buisness.
Reply:good luck for you... I hadnt got the chanced on the milling machine yet... will eventually...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Where did you get the anvils fo the english wheel???
Reply:Originally Posted by FlopWhere did you get the anvils fo the english wheel???
GMT+8, 2025-12-22 09:39 , Processed in 0.070334 second(s), 18 queries .
