So I needed a new gas nozzle for my Tig, lincoln 175 amp... the nozzle has external thread, as in the nozzle has male threads... brought it in to two local welding shops and they both shook their heads...Being as I hate the idea of not being able to get parts locally and the fact that my torch is beat to piss I went ahead and got a Weld Tec torch and accessory kit... but I'm still curious what kind of torch my welder came with.
Reply:probably for a Gas Saver set upEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I had a lincoln 175 amp that came with lincolns version of the wp-9 and it uses all of the same parts as the standard wp-9. If the front end looks fatter than normal it probably has a gas saver or gas lens on it. I would go to cyberweld or another online welding supply and look through what they sell and see if you can find it. It could also be a wp-17 size which is larger but its still the same deal. |
