smoker
发表于 2021-9-1 00:08:49 | 显示全部楼层 |阅读模式
going to start on a smoker/bbqis there a stander length the spilt wood(logs) come in want to make the boxso i dont have to cut 3 or 4" off to fit
Reply:Most people are going to cut 16 - 18". As far as a stated "standard", I have never heard of one.
Reply:all depends on where you live . i thinkhere in 0k most cut 16-18 some 20''but if your figure the (cord) ( the measure for wood) its measure is; 4x8 and if im correct 4ft wide with two ricks of wood so 24" would be a standard i  wood  check around your area  to see what they sellor if you cut your own, it don t matter
Reply:Look around at www.thesmokering.com before you make any hard and fast decicions.  Click on forums, then on the cookers section.  There are some stickys already there about dimensions.  These guys advocate that the firebox size should be about 1/3 the size of the cooker.  Here is a link to one of the stickys:  http://webpages.charter.net/tomchism...Calculator.htm
GMT+8, 2025-12-23 11:26 , Processed in 0.144657 second(s), 18 queries .
