Magnum 250L mig gun
发表于 2021-8-31 22:04:32 | 显示全部楼层 |阅读模式
I just bought a new 15ft mig gun from the local welding supply store when the liner went out of my existing 12ft gun. This newer gun has different nozzles and tips than my old 250L 12ft. My old gun came new on my Wire-matic 255, ~20yrs old. The problem that I'm having is the wire quits feeding every now and then because there is something snagging it in the tip. I put on a new tip or clean up the the existing one and it feeds fine for a while. Are these new guns crap or am I doing something wrong? I'd change tips on my old gun after the hole was wore out. I'm not very impressed with the new one.Sent from my iPhone using TapatalkMiller Thunderbolt 225 AC/DC, Miller Big Blue 302P,  Lincoln Wire-Matic 255 Mig, Lincoln Pro-Cut 55,  Milwaukee Dry Cut 14" Chop saw, Miller Digital Elite Helmet
Reply:Are you sure your drive wheels are tight enough? Might need the knurled drive wheels if your running Flux cored wire. Same problem was happening the other day with a welder and asked me what was the issue. I opened the machine and said pull the trigger, he pulled and welded fine then I saw the drive wheel slipping and it would quit feeding until it caught again. Check the wheels, eliminate feeding malfunction.
Reply:My PM215 came with the 15' magnum 250. Never an ounce of trouble."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:I have a magnum pro curve on the Thermal Arc, and it never gives any problems, love it. Is it burning back and sticking to the tip maybe.Thermal Arc 210 - Tweco 211I - Cutmaster 52
Reply:Thanks for the replies. I'll get a new drive wheel and see if that helps.  Since the welder has some age on it the wheel could definitely be worn and slipping.  The problem would probably be worse with the longer whip.Miller Thunderbolt 225 AC/DC, Miller Big Blue 302P,  Lincoln Wire-Matic 255 Mig, Lincoln Pro-Cut 55,  Milwaukee Dry Cut 14" Chop saw, Miller Digital Elite Helmet
Reply:drive wheel can definitely be an issue I have learned. Any more questions just ask. somebody on here can help lol!
GMT+8, 2026-1-3 05:15 , Processed in 0.104303 second(s), 20 queries .
