I ordered a sheet of 1/8" treadplate last week, and was going to have the vendor shear it to size so I could just install when it arrived. They advertise a 1/2" x 12' capacity for shearing, but told me when I ordered that they do not shear treadplate. I have sheared it in the past on our shear at work, and never noticed a problem. The salesman at the vendor could not answer why they don't, so I was hoping somebody on here could help me out with this.
Reply:I have never had a problem, from the shear in school to every shop I worked in that had a shear. It sounds like you need a new steel house.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Its because the lifted "tread" can chip the blade. I have actually seen it on a near new big shear.
Reply:Shear it tread down if chipping is an issue. Dan
Reply:Originally Posted by DanD78Shear it tread down if chipping is an issue. Dan
Reply:I buy mine sheared no problem. But 2 words if they won't, plasma cutter.Tim Beeker.
Reply:If the height of the tread is less than the capacity of the shear it is a non issue, period......Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:they are being babies.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I figured it had something to do with possible blade chipping and the shear operator being nit picky. I was able to plasma cut with no problems, just added a little bit of time to the job. As much as I would like to change steel suppliers, my options are very limited at my location, ecspecially when I factor in their delivery service. Thanks for the responses, I was wanting to make sure that I was not breaking any shearing rules.
Reply:Originally Posted by VPTBecause there is only one blade on a shear?
Reply:He's jerking you off! I call B/S on that, iv'e made a million cuts no problem, and if it was a issue for him then flip it over, bullsh!t.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I have seen shear blades chipped from it. Sure you might be able to get away with it maybe forever. But when I have 20 other cutting options I wouldn't risk my shear blades on it. |
