Need Help on Coolent Pump for FMB Phoenix Bandsaw
发表于 2021-8-31 22:04:27 | 显示全部楼层 |阅读模式
Folks , Been looking for a used horizontal band saw for quite sometime.   Wanted American made. Decided to go with Grizzly buy  My son found  a used FMB Phoenix (made in Italy but seems to be a high quality saw) at an auction and purchased. Got it home and decided to cut a piece of 4x4x 1/4 tube with it before I cleaned it up.  The coolant pump does not work.  Contacted the Distributor and they want $275.00 for a small pump plus tax and shipping.   Does any one have any idea as to where to find one more reasonable priced? Richey Attached Images
Reply:How much cutting do you do?I would just run the saw dry. My saw has fluid capabilities and I run it dry all the time.
Reply:VPY  Thats a good question.   Im retired and I just needed the saw for some repairs on the farm and projects.  I was fortuate enough to get 8 new M42 x1 1/16x 12tpi  included with the saw.  I think I may just try it for a while cutting dry and determine how many cuts I get per blade.   Thanks  Richey
Reply:I meant VPT  need to put my glasses back on.
Reply:Originally Posted by richeyVPY  Thats a good question.   Im retired and I just needed the saw for some repairs on the farm and projects.  I was fortuate enough to get 8 new M42 x1 1/16x 12tpi  included with the saw.  I think I may just try it for a while cutting dry and determine how many cuts I get per blade.   Thanks  Richey
Reply:Guess I couldnt see the forest for the trees.   Got some 2 in and 2 1/2 diameter hydraulic cylinder shafts to saw for pins but I am going to anneal it before I try to cut it. My son really lucked out on the band saw and I was really proud to get it. Richey
Reply:You can get a universal submerged coolant pump like this one http://www.wttool.com/index/page/pro...shopping=truee We have had somthing similar in our HE&M saw for the last decade or so.
Reply:Ben Iv   Thank you very much for this link. I had never heard of Wholesale tools. For this cost    I think I will order one of these tomorrow.   I do appreciate you responding to my request. Richey
Reply:I am guessing you have a northern tool in your corner of the woods, but they sell a electric pump for the parts cleaner bins for around 30 dollars that should work well.   It might be a little higher volume that what is normally on there but they are designed to work in a dirty environments.  Nice score on the saw by the way.
GMT+8, 2026-1-3 05:14 , Processed in 0.115650 second(s), 20 queries .
