Is this torch any good??
发表于 2021-8-31 22:04:27 | 显示全部楼层 |阅读模式
A guy I work with wants $50 for this torch and regulators. I might be able to test it out at work and I guess if no leaks and it works fine it's good to go. Just havent seen one exactly the same.Chicks Dig Body DamageMiller Dynasty 200dxHobart Handler 187Lincoln AC 225
Reply:50 bucks is a good deal, in my opinion. If you're nervous, check with your LWS to see if they repair torches and regulators..they should be able to clean them up and make them good as new.  Originally Posted by homemadexjA guy I work with wants $50 for this torch and regulators. I might be able to test it out at work and I guess if no leaks and it works fine it's good to go. Just havent seen one exactly the same.
Reply:Parts for the torch and regulators are obsolete and have been unavailable for many years from my suppliers.  Even if theye are working I would not purchase this set.OAdoctorwww.regulatortorchrepair.com
GMT+8, 2026-1-3 05:13 , Processed in 0.164092 second(s), 20 queries .
