Reduced price for bantam iron worker!!
发表于 2021-8-31 22:04:23 | 显示全部楼层 |阅读模式
The first $1000.00 gets the machine. I could have painted it and made it pretty but it works great! I'm in Rock Hill, SC. Just 15 minutes south of Charlotte [email protected] Attached Images
Reply:without searching what does the machine do? punch cut etc?
Reply:The machine punches and shears mild steel. The machine can be tooled to punch any shape hole and shear just about any profile such as top cap for railings. It's a good machine for the hand rail builder or any small fab. shop.
Reply:That machine is around a 1960s version.  Its missing all the safety guards on the fly wheel.  and the center guard on the clutch gear.  This machine has the old style clutch gear so it should also have the old style clutch. I am not trying to bust your balls here but your way high on your price for it.  I bought two of them for our shop, $1000 for one in 1976 beautiful shape with 4 shear blades and about 50 punches and $500 for one a 1987 that had plenty of use but had a brand new clutch on it and still looked good. I just had a guy ask if I wanted to buy two 2005 machines for a $1000 a piece each with tooling that where only used on aluminum.  This machines is worth $400 tops because of its age and its missing all the safety guards. Along with the stripper for the punch head.  It looks to only have the straight shear blades.  Not the 2"x2"x1/4" angle, 5/8" square, 1/2" round and 1" flat standard combo shear blades it should had. The bantom, aka bateman or rogers 10 ton ironworker was designed by a Mr. Bateman in 1956 for his railing shop.  Which the correct profile combo shear blades, it can be set up to cut 1" channel, 1.25" cap, 1/2" picket and 1" flat bar .  Then be also set up with a 1/2" square punch to punch the channel for pickets.  All you then need is a grinder, welder and you can make rail.  You still can buy this machine new today still made in the same factory as the original 1956 model.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
GMT+8, 2026-1-3 05:12 , Processed in 0.103818 second(s), 20 queries .
