trailblazer 302
发表于 2021-8-31 22:03:47 | 显示全部楼层 |阅读模式
what are all the types of welding cutting you can do not a clear picture from website
Reply:with the TB 302?   stick, tig, mig/flux core and carbon arc cutting and gouging.   Of course to do any of these processes takes the right accesesories.  For insance, to stick , you need leads and stinger and work clamp.   For tig, you can do scratch tig, or you can get a HF unit and remote.  You will need tig torch.  Mig/flux, need a feeder.  Carbon arcin needs a carbon arc stinger and air compressor.   Does this help?IF it Catches...Let it Burn
Reply:im new to the biz is any of that plasma cutting
Reply:oh and what are good online stores for that stuff
Reply:There are no attachments that do plasma cutting from an engine drive that I am aware of.You use the same plasma cutters that you buy for a shop, you just plug them in to the engine-drive's auxiliary power (120/240V) receptacles.www.cyberweld.com is one place that has excellent prices on engine-drives and other welders and accessories.
Reply:I just got the 302 and its sweet as. the only way you can do plasma is if you plug it into the 240 plug and then plug in your compressor. not sure if it works perfectly, but it should do. the machine paid for its self the first day. good asset if you ask me.the thief of hearts     www.jamfab.com
GMT+8, 2026-1-3 05:07 , Processed in 0.113279 second(s), 20 queries .
