Bought a Millermatic 200 was welding perfect. Wanted a spoolgun so bought one off of ebay. Would only work gas solenoid so was gonna tap wires from drive motor into the fou pin plug but I guess I got them reveresed. When I pulled the trigger it clicked. Breaker by the roll of wire had popped out when it clicked but must have done something else too because now will not feed the wire. Only thing working is gas solenoid. A friend had told me you could wire it in. Wish I hadnt even tried now. Anybody have any idea of what else I could have messed up?
Reply:Several members here are experts at this and will surely reply to help you.They will need to know how many pins are on your MM200 for the spool gun plug receptacle, serial # of your MM200 and make and model of spool gun you are attempting to hook up to it."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
